| Subject |
Help with engine miss at idle |
| Posted by |
white22sky on June 18, 2011 at 9:02 AM |
This message has been viewed 471 times. |
| Message |
I know this symtom has been covered many times, I've searched and madesome repairs but nothing has improved. To start I bought the vehicle with a miss (got a good deal on it). I went through the 6ps, performed some diagnosis, ohm injectors, check timing, boost leak test,compression test. I found a couple of hoses cracked and replaced, also found two bad injectors and replaced all six. I do not have any problems while driving everything seems to be in line, it boosts fine no hesitation etc. The only problems I found were the injectors and hoses compression was fine all six were between 155-165 psi. Those repairs took care of the miss and the car barley even being able to accelerate, but now at idle I have this ever so slight miss, rpms dont noticably change and idle feels smooth except you can feel this little shutter in series of two or three every 15-25 sec. Thanks for any ides in advance.
| Follow Ups |
- Help with engine miss at idle - white22sky
09:02:29 06/18/11
Post a Followup |
